Contain problem on ST3
Hi ST3 users,
Have you got the same problem?
When I extrude a fully constrained sketch, the extrusion operation on pathfinder is considered as not fully constrained.
Thanks for your replies.
MERMET Sebastien
Mecanical & Product Designer
SolidEdge ST2 & Unigraphics NX4 & 6
Dell precision 490 & Dell precision M6300
RE: Contain problem on ST3
Hi all,
I just installed SP2 and it seems that the problem
been fixed, this problem has disappear on new part
created.
Thanks, swertel, for this good idea.
Regards.
MERMET Sebastien
3Dpresta - Mold & Product Design
SolidEdge ST3 & Unigraphics NX4 & 6
http://sites.google.com/site/3dpresta1/
I looked up the text files for MP1 and MP2, I don't see anything in there regarding the issue you are seeing.
I tested this on ST3 MP2 and could not reproduce the problem.  The pencil icon does not show when I have a fully constrained sketch.
But, by default, the sketch colors do not update.  When in the sketch environment, you have to go to the Inspect tab, Evaluate group, and select Relationship Colors.  Turn that on and make sure all of your sketch elements turn black.  If they don't, that would be the area were the sketch isn't fully constrained.
--Scott
http://wertel.eng.pro
Hi swertel,
I have also look on the MP text files, and don't see anything.
Regardless, I haven't problem since MP02...
A new thanks to you swertel : concerning the color relationship of the fully constrained sketches winky smile
Regards.
MERMET Sebastien
Hi all,
Unfortunatly, I have always this problem of constraints on extrude operation...
An idea?
Thanks.
Regards.
MERMET Sebastien
