Surface 'magically' turns grey??
I'm building a surface model from sheets and have found that two 'variational sweep' surfaces have magically turned grey.
It's the sort of light grey that would suggest they are not the work part (but are).
The 'Edit Object Display' dialog suggests they should be 'Pure Green'.
It happened after I modified a sketch ... however .. the surfaces in question are earlier in the history tree and are unrelated to this sketch.
Closing and opening the part doesn't resolve this.
It's not stopping me using or modifying these sheets but is plain bizarre!!!
Any ideas?
Jon S
Medical Design Engineer - Glos. UK
NX 6.0.5.3 / Teamcenter 8
RE: Surface 'magically' turns grey??
Have you been messing with the 'Grid'?
Go to...
Preferences -> Grid and Work Plane...
...and check the status of the 'Dim Objects' toggle in the 'Objects Off Work Plane' section of the dialog.  If it's ON, toggle it OFF.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Hi John,
No - the grid settings are unchanged.
This is two very specific variational sweep surfaces, all other surfaces are fine.
Jon
Is it possible that you've edited the color of the face, but not the surface?  Set you filter to only faces and select that 'face' of the surface see what color it's set at.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I've been having components pick up 'specific translucency' in an assembly after being edited in assembly or as the displayed part.  Its annoying, I have to uncheck that option each time it occurs.
It sounds like a similar problem.
NX 7.5.0.32
NX 7.5.0.32 MoldWizard
You have to keep in mind that if you edit the color/translucency of a component while you're working in the context of the assembly, that you have ONLY edited the appearance of that Component for THIS one assembly.  The original part file knows nothing of those edits.  Now if you go back and edit the original piece part and change it's color, when you go back to the Assembly where you had previously edited it, nothing will have changed since the edits in the assembly will override the original color even if you edit later on.  If this happens and you wish to remove (not just edit the component so that it LOOKS like the original model), while in the assembly, select the component of interest, press MB3, select 'Properties' and in the 'Assembly' tab, toggled OFF the item titled 'Specific Component Color'.  Note that if this toggle is NOT selectable it means that the appearance of the COMPONENT has not been edited in this assembly.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I'm well aware of how the object display colors etc work, this is NOT operator error.
If I make a component the displayed part, add a chamfer or hole, then make the top assembly the displayed part, it will have set that component in the assembly to have zero translucency.  I have to un check 'specific translucency' to undo this errant change.
To restate, the software is changing component display properties on its own random whim at times when I am not making any changes to any display properties.
I'm afraid that you're going to have to take this up with GTAC and have them look at your files.  Without having the actual files so that I can see what's happening, I'm at a loss for suggesting anything else that might possibly be causing this behavior.
John R. Baker, P.E.
Industry Sector
Cypress, CA
