Testing faraday cage (room)
I would like to test a Faraday room that has been built to do some R&D work. Don't have much money to get proper instrumentation so I would like to do it on the cheap.
I have oscilloscopes and can make up some instruments.
I assume I will need a EM detector to work over a spectrum 0-3 GHz to place inside faraday room and a EM source of variable power and frequency to place outside.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
RE: Testing faraday cage (room)
Dan - Owner
http://www.Hi-TecDesigns.com
Safety Advice: Make sure the door latch is fail-safe, or you have safety processes in place. One wouldn't want to working late on a Friday and be trapped inside.
Keith Cress
