Defining plasticity
Defining plasticity
I have a stress vs strain curve of a material and want to define a elastic plastic model. From the curve, I filled in the values of yield stress and plastic strain. Since the analysis is nonlinear, I will have to define the load with respect to time i.e. time dependent load (history loading). For that steps have to be defined. How do I define steps in order to make abaqus understand about the elastic as well as plastic region?I am not very clear on how to define the time period, the increments even after going through the manual.
Is it like the first step which would be defined should be linear region, the second should be yield point the third plastic deformation and so on?
Can anyone explain me in detail?
Thanks in advance.
Thanks in advance.
RE: Defining plasticity
/Stig
