LM6 SN Curves (or other fatigue data)
Hi all,
I know this question was asked a few years ago (with no answers) but the thread has been closed so I'm not able to comment on it (see thread330-170605: LM6 Aluminum S-N Curve / Goodman Diagram).
Does anyone know where I can find SN data for LM6 aluminium alloy (or any other fatigue/fracture data)?  I have the fatigue strengths at various temperatures but like the previous poster I am looking for the curves themselves.
I've done a literature search and looked in a number of books/papers but can't seem to find anything!
Alternatively if there is a means of generating the curves myself that would be fine.  The fatigue strengths (@10^7 cycles) I currently have are:
52MPa @ 20 degrees C
44MPa @ 100 degrees C
33MPa @ 200 degrees C
25MPa @ 300 degrees C
Thank you
Dan
RE: LM6 SN Curves (or other fatigue data)
You won't find a great deal of data on the fatigue properties of LM6.  Try searching using the newer European designations such as AC-44100, AC-44200 or AlSi12 (BS EN 1706).  Here is one reference that shows an actual curve (ambient temperature only):
http://books.google.com/books?id=TnHJX79b3RwC&pg=PA191&lpg=PA191&dq=aluminium+fatigue+AC-44100+OR+AlSi12&source=bl&;ots=dBP6zfJO87&sig=ai0tbPxVevguasbN-e7_CeFluQU&hl=en&ei=HrtJTc6zKIWClAfmvMnsDw&sa=X&oi=book_result&ct=result&resnum=10&ved=0CEEQ6AEwCQ#v=onepage&q=aluminium%20fatigue%20AC-44100%20OR%20AlSi12&f=false
Keep in mind that the fatigue strength will be greatly dependent on the amount and location of porosity, and to a lesser extent, on the grain size and secondary dendrite arm spacing.
