Revolved boss as Design Library feature problem
So I'm attempting to set up a male 37° JIC "boss" in the design library as a revolve with configurations. Problem is, I can't figure out how to make it so I can drag the feature onto a face without it wanting to put the revolve sketch onto that face instead of the end of the revolved boss. I have looked on the SolidWorks online help and there appears to be an issue with revolved features in the design library. Any thoughts?
RE: Revolved boss as Design Library feature problem
Dan
www.eltronresearch.com
Dan's Blog
Attached is a part file, I'll also post the library feature that is created from it, it might give you some ideas.
mncad
mncad
