Xpresreview 8.1 on windows 7 64 bits
We have installed Xpresreview on windows 7 64 bits without any problem and following the information found on uganswer, we have renamed:
C:\Program Files\Siemens\XpresReview\Program\C
to
C:\Program Files\Siemens\XpresReview\Program\fr
Then xpresreview start without any error message but it is blocked
and If we use File / Send to package File from NX7.5, we have the following message "xpresreview seems to be not installed ..." !!!
We can say also that the same installation work very well on windows XP.
Does anybody have any experience using xpresreview 8.1 on windows 7 64 bits ?
TIA
to
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: Xpresreview 8.1 on windows 7 64 bits
Using an ascii editor, create a .reg file containing the following to create the required registry entry. Save the file double click, "yes", ...
Regards, Joe
CODE
[HKEY_LOCAL_MACHINE\SOFTWARE\UGS]
[HKEY_LOCAL_MACHINE\SOFTWARE\UGS\PCF Viewer]
[HKEY_LOCAL_MACHINE\SOFTWARE\UGS\PCF Viewer\CurrentVersion]
"InstallPath"="C:\\Program Files (x86)\\Siemens\\XpresReview\\Program"
"Program"="XpresReview.exe"
