Parking Layout - wide aisles, narrow stalls
I have a site which is long (east to west) and narrow (north to south).
After laying out three bays of parking stalls, I find myself with some extra space in the north-south direction - not enough to get another bay, but enough to make my aisles 28 feet wide instead of the required 24'. That got me thinking.
Given that the aisles can be much wider than required, would I have a leg to stand on for making the stalls narrower than the 9' typically required (maybe 8.5')? That way, I would pick up another two stalls in each bay
Thoughts?
Thoughts?
RE: Parking Layout - wide aisles, narrow stalls
The depth of the parking stall can be decreased as the aisle width is increased, but not sure how you argue that an increase in aisle width = decrease is stall width.
Try different stall angles to better utilize the lot.
As far as the stall width: minimum standards are just that (minimum). While there area codes local to me that allow 9 ft wide stalls, I personally hate using them. I try to design 10 ft even with a 9 ft minimum. 9 ft stalls make for doors banging into the adjoining car and difficult vehicle access with innacurate parking of users.
You may be able to reduce the isle width slightly depending on the type of parking. In an office with the same people using the same stall, it may be possible to slightly reduce the width due to the familiarity of the parking space and process. In a shopping centre, where parking is 'casual' and there is no familiarity, then full sized stalls are the norm.
If critical, consult a parking planner if OK by the building/planning department.
Best check with your building/planning department.
Dik
Thanks, everyone, for the input.
