Heat control for machine-room-less elevator
Machine-room-less elevator with the drive motors at the top of the shaft. Has anyone seen these installed?
How is the motor heat (in my case just under a ton for two elevators) controlled?
I would think the operation of the elevator in the shaft may take care of it. On the other hand the motors are in a raised area of the roof.
RE: Heat control for machine-room-less elevator
Even though it doesn't require a "machine room", it still has control panels that require locating and believe it or not, cooling. Don't forget the panel cooling requirements.
knowledge is power
