L-605 cracking
L-605 cracking
What is the major cause of cracking in L-605 alloy?
We have struggled with problem on and off for years and never figured it out.
Thank you
Thank you
RE: L-605 cracking
Can you provide some additional background information as to use of this material in service??? What type of cracking???
RE: L-605 cracking
The major amount of cracking has been of a stress corrosion type making our cleaning suspect.
However we also trying to anneal with a vacuum furnace and the ramp up to temperature is slow
and the quench is on boarder line of being to slow.
Thank you
RE: L-605 cracking
RE: L-605 cracking
We are trying to use a 2 bar vac furnace with helium argon mix
