Seismic R value less than 5
I am looking through a design example in the NEHRP (FEMA 451) Recommended Provisions Aug 2006 and it states that "if a value of R in either direction is less than 5, the smaller value of R must be used in both directions".
It references NEHRP 2000 sec 5.2.2.2.1 (2003 sec 4.3.1.2) for this provision. I cannot find any such provision in ASCE 7-05 chapter 12.2. Does anyone know if this is / was an ASCE seismic design requirement?
For the project I am currently looking at, this provision will not govern, but I am just curious for future situations if I should be aware of the R less than 5 rule.
RE: Seismic R value less than 5
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
4.3.1.2 Combinations of framing systems. For those cases where combinations of structural systems are employed, the designer must use judgment in selecting appropriate R, Ω0, and Cd values. The intent of Sec. 4.3.1.2.1 is to prohibit support of one system by another possessing characteristics that result in a lower base shear factor. The entire system should be designed for the higher seismic shear as the provision stipulates. The exception is included to permit the use of such systems as a braced frame penthouse on a moment frame building in which the mass of the penthouse does not represent a significant portion of the total building and, thus, would not materially affect the overall response to earthquake motions.
Lastly, it does not apply to single and two family light frame construction. At least not in the 2003 version.
