definition of "rotodynamic pump"
ISO 10816-7 is intended to apply to "Rotodynamic pumps for industrial application". Similarly ANSI/Hydraulic Institute 9.6.4-2009 is also a vibration standard for "Rotodynamic pumps" Some sources simply say "centrifugal pump."
Does ISO or industry normally consider an open 3 bladed propellor (axial flow, primarily) agitator a rotodynamic pump?
thanks
Dan T
thanks
Dan T
RE: definition of "rotodynamic pump"
(2B)+(2B)' ?
http
Generally any pump that has a rotating element imparting energy to a fluid to cause it to flow.
Ted
