Precision of Hole diameters in a hole table
First posting, so apologies if this is 'obvious' to many....
I've just migrated to 2010 & when doing a hole table, I can alter the precision of the location of the holes but NOT the diameters. e.g. a hole created at 1.15 shows as 1.2. Any ideas of where to go to change the precision?
RE: Precision of Hole diameters in a hole table
With the drawing open:
Under 'Tools' -> 'Options' -> 'Document Properties' Tab -> 'Units'
The first line in the table should be Length, and to the right is the Decimals collumn.
Use the pull-down menu to change the precision.
Good Luck
Oh sweet. Thank you. I was trying to 'force' it from the hole table properties.
