High Temperature Scrapped Surface Heat Exchanger
Greetings,
In the middle of a front end design for a high temperature (230-250 C) process (CSTR) that involves reacting fatty acids.  Need to transfer lots of heat as the reaction is endothermic.  The mixture is also viscous so considering using a pump around with a scrapped surface heat exchanger to enhance heat transfer.  The only experience I have with these heat exchangers has been with low temperature applications.  Does anyone have any experience with and/or vendor recommendations for high temperature (270-300 C design) units?  I have looked around to some extent but was hoping to get some helpful information ahead of time.
Thanks in advance,
JoeChem
RE: High Temperature Scrapped Surface Heat Exchanger
You mean "scraped surface".  Look for people who make wiped film evaporators.  People like Lewa and Rototherm come to mind.
side from the post above by moltenmetal two others that I'm acquainted with are by Delaval and Rototherm.  There were a couple of Delaval's in the pilot pant and the Rototherm one was used in recovering a by product.
At time we operated a pilot process using both single and twin screw extruders.  The link is the one to give you information and not the one we used.  there is also a single screw reactor that I can't recall the name.
Make sure you run some corrosion test to determine you MOC.  Work I've done with fatty acids at high temperature MOC was a big concern.
http://www.artisanind.com/ps/docs/rototherm.pdf
http://www.clextral.com/en/plastic-et-chemical/advantages-of-clextral-twin-screw-extrusion-200.html
