surfaces to solid
surfaces to solid
surfaces to solid
I want to know how can I pass surfaces to solid in NX.
RE: surfaces to solid
Sew them together (insert - combine bodies) or patch. But keep in mind that you need perfectly fitting sheets, you can however play with the tolerances. Or make use of the heal geometry function.
Best regards,
Michaël.
NX4+TC9 / NX6+TC8Unified / NX7.5 native
Insert > combine bodies > sew
You may, or may not, be able to sew them all together at the same time.
