Limits and fits
Limits and fits
Hi, what is the correct way to dimension upper and lower limits for holes on a drawing. Should the MMC be above LMC? OR the higher value be above the lower.I prefer the latter to avoid confusion but I have been told that the former is the correct way.Please advise
RE: Limits and fits
John-Paul Belanger
Geometric Learning Systems
RE: Limits and fits
The point is, no one can tell you what is right or wrong until you tell use what standard you are using.
RE: Limits and fits
The high limit (maximum value) is placed above the low limit (minimum value). When expressed in a single line, the low limit precedes the high limit and a dash separates the two values.
You may also find it on Y14.5-2009 Sec. 2.2 at page 24 as well.
SeasonLee
RE: Limits and fits
