Creating a New Hole Type for ANSI Metric
I'm looking to add a tapped hole type to an existing standard.  I have M14 x 1.5 and I'm looking to create a M14 x 1.0.
I have SW 2008.
How to do it?
RE: Creating a New Hole Type for ANSI Metric
Yes I did see this but I'm not looking to create an entire new standard.  Would just like to add a thread size to an existing standard.
That is how it is done in SW. After the new standard is created for customization, any unwanted portions can be deleted. When creating a custom hole it is a very simple on-the-fly selection to switch from the standard to the customized database.
You could go into the main Access database but that would void SW support.
Jterry,
     The best way is to modify the SWBrowser.mdb database.  Make a backup of this file first, just in case.
     Open it up and look for the AM_DATA_HW_TappedHole table.  This is where the Hole Wizard gets the Metric tapped hole information from.  Add a new entry for your M14x1.  You also have to add the tap drill size.  Open the AM_DATA_HW_TapDrills table and add a new entry.  Keep the SIZE description the same for both. And finally look for AM_DATA_THRD and add any entry.  This is where you put all the information in about the threads.  Make sure you use the same size description everywhere.
     I have modified this database extensively for our company standards.  It's no big deal.  Mostly it is just hard to find what you need to change.  Good luck.
Chris
