Openings in Structural Concrete Tees
I need to know where the best place to locate an opening in a structural tee roof system. The mechanical engineer wants to place an 18"x36" over the joint of two tees with the long dimension running along the joint. Is this the best spot or should it be located more towards the interior of the tee? Once the location of the opening is determined, are there any special blocking requirements?
RE: Openings in Structural Concrete Tees
BA
BA
