13th AISC Code Requirements for Shear Connection Ductility
Does anyone have any references for finding the rotation of a double angle connection into the column web for a plate girder? Our consultant modeled the structure as a pinned structure but there are no expansion joints in the steel. So i started looking into the connection requirements. The code is very prescriptive -i.e. use table 10-1 and you know that your connection meets the ductility requirements. However, the plate girder isn't covered . has anyone else had to deal with this and found any good references for knowing how to check this?
RE: 13th AISC Code Requirements for Shear Connection Ductility
I got 350 heads on a 305 engine; I get ten miles to the gallon, I ain't got no good intentions.
"Note that this approach can also be used to demonstrate adequate rotational ductility in other simple shear connections that flex to accommodate the simple-beam end rotation, but with configurations that differ from those prescribed in Part 10."
