Elastic modulus: steel vs brass behaviour
Am trying to figure out the variant in the behaviour of steel as compared with brass. The elastic modulus for steel is greater than that for brass. I want to find out which woould stretch more easily and which is stiffer.
Thanks for help.
Thanks for help.
RE: Elastic modulus: steel vs brass behaviour
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Plymouth Tube
