Rename existing custom propeties
Hi
I have a number of parts that were set up with the custom property PartNo and a number of parts that were set up with the custom property Part Number.
If these parts are used in an assembly together the BOM shows only the PartNo (or Part Number depending how I set it up).
Is there a way I can batch rename PartNo to Part Number in all older parts to get some consistency?
Thanks for you help
Thanks for you help
RE: Rename existing custom propeties
FAQ559-1429: How To Change Or Manage Document Properties And Templates.
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Also, custom properties are caps-sensitive.
SW 2010 SP 4.0
CorBL, the interessting links do not work properly, but I will have a look if I find something suitable
Edit your list of Properties to include "Part Number" instead of just adding it to each part file. If there is valid data under "PartNo" just change the property name to "Part Number".
If there is data in both of them and "Part Number" is bogus but "PartNo" is good, rename "Part Number" to "PN", then rename "PartNo" to "Part Number"
I'm sure this could be scripted . . .
"Been there, done that, got no tee shirt"
SW 2010 SP 4.0
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
Still, at least there aren't any issues with associativity. e.g. If you delete a property and create a new one with an identical name, none of the drawings or other things dependent on the property are affected.
