signal 11 caught in file ...
i'm on a problem i can't solve. Nx7.5 on one of my Computers throws an excenption and i cant find any hints what to do. I hope you can give me some tips what is wrong with this installation of nx.
Here is a short part of my errorlog:
*** EXCEPTION: O/S ERROR: signal 11 in line 1852 of o:\ugnx752\ip5\src\syss\error\ind\error.cxx at Mon Jan 31 10:38:44 2011 Westeuropäische Normalzeit
+++ General Fault Exception
[ 1] 012FEBDA (libsyss)
[ 2] 012FF08E (libsyss)
[ 3] 090B73DF (libpartmodl)
[ 4] 090C043A (libpartmodl)
[ 5] 090C1640 (libpartmodl)
[ 6] 090C279D (libpartmodl)
[ 7] 1385098F (libmodlint)
[ 8] 138486EF (libmodlint)
[ 9] 1372B050 (libmodlint)
[10] 11F3BDBE (libugui)
[11] 11F3BF81 (libugui)
[12] 11E05FF3 (libugui)
[13] 14CD03FA (windowsui)
[14] 14CD0755 (windowsui)
[15] 11F769C1 (libugui)
[16] 11F3C172 (libugui)
[17] 11F769E9 (libugui)
[18] 105D4BD7 (libuginitint)
[19] 00402E87 (ugraf)
[20] 00401DAF (ugraf)
>>>> O/S ERROR: signal 11 caught in file "o:\ugnx752\ip5\src\modlint\no\ind\udfs_ui_instantiation.c" at line number 3345
>>>> O/S ERROR: signal 11 caught in file "o:\ugnx752\ip5\src\ugui\no\ind\uigblfunc.c" at line number 461
>>>> O/S ERROR: signal 11 caught in file ".\EVTLoop.cpp" at line number 1646
>>>> O/S ERROR: signal 11 caught in file "o:\ugnx752\ip5\src\ugui\no\ind\uigblfunc.c" at line number 275
>>>> O/S ERROR: signal 11 caught in file "o:\ugnx752\ip5\src\uginitint\no\ind\modl_ui_menu.c" at line number 4301
&MACRO FOCUS CHANGE IN 1
&MACRO MESSAGE_BOX -2, Error recovery completed for the following error:
&MACRO MESSAGE_TEXT Internal error: memory access violation
&MACRO CURSOR_EVENT 1001 3,1,100 ! single_pt, mb1/0+0, U_Sel_sngl (P+:0+0)
&MACRO CPOS 123.809608924116,32.3815908640433,-11.825705705633
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR ! <MB/Toolbar>
The error occurs on loading udf's. The same udf's are used by 50 other computers as well and work fine.
Bernhard
RE: signal 11 caught in file ...
contact the GTAC,
report a problem -> Help menue
regards
