Witness of Pressure Relief Valves Testing
Hi All,
During our maintenace activity of the Pressure Relief Valves,does the inspector or the witnesser of the test need to be certified to do that activity or the awarness of PRV repair and test is adqute for that?
Also what is the certificate if there is?
Thanks for the usual support..
Yours,
YHAMDI
Mech. Eng.
RE: Witness of Pressure Relief Valves Testing
Not sure if you know that there is a special Safety Relief Valve Engineering Forum here at www.eng-tips.com. I think the specialists there can help you.
