Making sheets a solid body
According to this thread:
http://www .eng-tips. com/viewth read.cfm?q id=287332& amp;page=6
Making a sew of watertight sheets produces a solid. How can I verify that my object is, in fact, a solid?
Also, why is it that when I sew a body together it sews, but when I use the sheets to solids assistant, it is unable to sew with the same tolerance? I can't get the sheets to solids assitant to make my body a solid by any means.
Also, by my understanding, a sheet boundary is a crack in the model between sheets. Is this correct? How can I mitigate/remove them? So far I have been importing my IGS exports to ANSA, fixing the geometry issues, and exporting them back to NX. Is there a better way to fix boundaries in NX?
I am using NX7, by the way.
Thanks for any help!
http://www
RE: Making sheets a solid body
Now if it turns out that the model is still a sheet body due to 'cracks' you could open up (set to a larger value) the tolerance used in the Sew command. Or you could try going to...
File -> Export -> Heal Geometry...
...and see if that fixes the cracks (you may have to perform the sewing operation again).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Mike
I really appreciate both of your guys' help.
