PBT Chemical Resistance to 5 percent acetic acid solution
I have a food contact application and want to use PBT @ .8 mils. The application is a pickle jar closure.  Predictive test protocol demands placing the closure in a 212F five percent acetic alcohol / two percent NaCl solution, then allowing to cool to 120F for thirty days. Will PBT survive.
RE: PBT Chemical Resistance to 5 percent acetic acid solution
Without referring to published data, I say it will do it easy however you should look up the manufacturers chemical resistance charts.
From memory, manufacturers are:-
GE/Sabic with Valox
Bayer with Pocan
DSM with Arnite T
Ticona with ? (Maybe Duranex or Hostadur)
BASF with Ultradur.
DuPont with Crastin
There are more, but they escape my mind now.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Go to the supermarket and checkout what they are using for vinegar containers.  Better yet buy a few different brands and checkout the cap liners.
also thee people that supply you with cap liners should be able to tell you right off.
I have only seen PBT used for tooth paste cap liners because of its excellent flavor scalping properties. The caps on my vinegar bottle are I believe PP with a foam wad. Probably PE foam.
Certainly PET has excellent resistance to acids, up to and including boiling strong sulphuric. I presume but have not confirmed PBT is similar.
I also expect PP would work for this and wonder why PBT is specified.
Pat
for site rules
