CWI exam / open book D1.1 ??
Could not find the answer to this in the AWS literature so I am curious to know if you can use your own copy of D1.1 during the exam or do they provide a copy?
I know if you take the seminar they give you a copy but I own an electronic (PDF) version of D1.1-2010 and I printed a copy and have it in a 3 ring binder.
Is this going to a problem?
Also, is a copy of D1.1 the only book you can use during this part of the exam?
During the ICC exam you can have whatever you want with you so I was wondering what AWD allowed.
RE: CWI exam / open book D1.1 ??
The electronic versions do have some negatives:
1) can not cut/paste for reports
2) won't allow a double-sided print. Had to print the entire thing single sided and then run it back through for 1 side to 2 side copy. You loose a with each generation.
Best regards - Al
If you need to cut/paste for a report, you can do a print screen and:
1. Paste screenshot directly into WORD/EXCEL
2. Copy the screenshot into MS PAINT,select the area you need, highlight/copy/cut then and place into your report.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
