welding inspection tools? & CWI exam
Looking at the AWS inspectors tool kit I see there is a caliper and a 0-1" micrometer.
FYI, I work for a testing lab (don't hold that against me) and do mostly construction inspection work.
I already have most of the tools in the kit but not a good caliper or 0-1" micrometer.  I understand that the caliper and micrometer that come in the AWS kit are super-cheap-o.  On the other hand, for the rough-and-tumble environment of the job site how high-quality a set do I really need?
And how often will I really need these?  I don't think either of the CWIs at my office even carries these.  Although they are VERY secretive as a rule: I mean not at all interested in training anyone else, at least not during a recession.
RE: welding inspection tools? & CWI exam
BT...a good caliper is handy, but you don't often use a micrometer, particularly for building construction work.  I have both Mitutoyo and Starrett calipers.  Both are excellent and use a dial indicator.  I also have a vernier caliper, but I don't used it anymore.
The one time I used a caliper on the job was where I couldn't tell whether a shiny spot near a plate edge was where they just ground out a defect or made an unauthorized welded repair.  Someone actually had a micrometer, and I used it to verify that the "ground" spot was actually thicker than the surrounding area.
That was 10 years ago.
Hg
Eng-Tips policies:  FAQ731-376: Eng-Tips.com Forum Policies
Rarely use a mic, but have used a caliper on many an occasion.  Primary purpose was to verify min wall thickness on counter-bored eccentric pipe.
