Use of wa x for undisturbed samples (shelby tube/block sample)
Anyone can suggest what kind of wax can be used for waxing the shelby tubes or block samples ?
The drillers said that they use "bee's wax". I wonder if you can use "parowax" block, commercially available for canning, waxing, etc. The problem, I believe that this wax is rather brittle. Is there a mix (such as oil,etc), which can be used with parowax, so that it becames more plastic ?
RE: Use of wa x for undisturbed samples (shelby tube/block sample)
It needs to be kinda brittle so you can dig it out of the tube.
Danny McCook, Natural Resources Conservation Service Laboratory, Fort Worth, TX
If there is no paraffin available, I throw in a handful of vaseline (preferably the unscented kind unless you want to be the "butt" of some jokes by the drillers on how nice your work area smells.
