Grip file for extracting point locs and attribute info..
I'm looking for help on creating a grip file to extract
x,y,z, locations as well as userdefined attribute info to
a textfile or info window for points.
RE: Grip file for extracting point locs and attribute info..
hai its easy man.....one GPA(global parameter access symbol) function is there to read attributes from objects...
so u can filter point using MASK and read the attribute and show it in text file as information
if u want more help i will write one program and send to u
Yes please, send me a source code file for the program you are talking about.
Is that a grip file with the extension *.grx?
Will this only print out just the x,y,z and attribute info,
and none of that other junk like file information, layer,color, etc.
Sny-d
u tell ur full requirement..i will deveop and send to u as grs and grx.u send ur req: on my mail saju_prab@yahoo.com
