Windsor Probe Testing
Has anyone ever had an issue performing the Windsor Probe system where one of the probes in the triangle plate went too deep. What could cause something like this? All other samples worked out ok, just one area where I could not get a reading. Lightweight Concrete 3000 psi design, gold probes used on Moh's #3, used correction factor just curious if anyone has ever seen this before.
I say operator error on my part. What do you think?
RE: Windsor Probe Testing
Windsor probe is subject to surface irregularities and near-surface irregularities, including voids, soft aggregate, bleeding, etc.
When you encounter such, move over a few inches and repeat the series.
Thanks to all
