SE V20 Coordinate Dimension style
I'm using SE V20 and have been experimenting with coordinate dimensions. Is there a way to make the dimensions vertical in a draft document while using coordinate dimensions.
Becky
Becky
RE: SE V20 Coordinate Dimension style
If memory serves at times in the past we may have created separate styles at one point for vertical & horizontal but I can't recall before.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
