Bending 90 elbows - Vibration issues
Dear all,
I am bending 90degrees elbows in this machine:
http://unisonltd.com/76mm%20pictures.htm
I have issues with heavier tubes (stainless) as they tend to vibrate a lot as they extend. Any ideas? Does anyone ever used dampers on these?
thanks
RE: Bending 90 elbows - Vibration issues
Bleed the hydraulics.
Mike Halloran
Pembroke Pines, FL, USA
Are you using SS tubes with less than 1.5mm thickness if using the mandrel wip die?
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
