Disconnect Switch Frequency Ratings
I am looking to replace some open copper bussing and home made knife switches at an industrial site with listed and labeled equipment. The first problem I am running into is the disconnect switches that I would use to replace the knife switches are going to be exposed to 500V high frequency. They are feeding induction heating furnaces. Does anyone know if a standard off the shelf disconnect switch rated for 600V will work? Do they have a frequency rating? What is it, 60 HZ?
Any other considerations I should think about? What about standard bus duct if I were to replace the open copper bus bars?
RE: Disconnect Switch Frequency Ratings
