Ideas NX .prt inport into ideas/UG/??
Greetz all,
A customer has just sent me a Ideas .prt file.
no .pkg file just the .prt
Is there a way to activate this part?
I have thought of creating a dummy .pkg file and replacing the file name in it.....
so far no Joy
Ken
so far no Joy
Ken
RE: Ideas NX .prt inport into ideas/UG/??
Thanks for the reply,
I'll keep working on it.
Ken
1.-You create a part (a cube, cilinder, whatever you want) and you place it into the library.
2.-Once it is created, you go to the folder where it is stored the *.prt file of this new part. (usually ...in team/shared...) and you delete de prt file or you move it to a different folder
3.-You go to the manage library, click on this part and do a recconnect file, chosing the *.prt that the costumer sent you.
Maybe it will work
This did get it so I could see the part. Not sure if it's in the correct position in car. But I can check that later.
Thanks again.
