Does a 1200A switchboard require a separate fire rated room?
Is a locked cage around the equipment adequate?
RE: Does a 1200A switchboard require a separate fire rated room?
David Castor
www.cvoes.com
If you have oil filled transformers or dry type transformers over 112.5 KVA, they do not need to be a dedicated room but the room must have a fire rating.
By making it its own room there are exceptions you can sometimes take to sprinklering the room in NFPA 13.
Where are you in the world?
The rules can vary by locale.
