mantain link with 3d parameters in the second sheet or more
Hallo to everybody!!
As usual i'm here to find a solution.
In Nx5 i've created a drawing template(using pax file and personal palette) with
the annotation in titleblock linked with 3D's attributes(defined by the user).The
problem is that when i have to insert the second sheet, the  links of the annotations of the
titleblock in the second sheet are lost,
Obviously this happens also with the third and so on..
Any idea?
Thanks for all
RE: mantain link with 3d parameters in the second sheet or more
No one has an answer?
I was thinking to link 3D's parameters to drawing's parameters but at the moment i'dont find the right way
Well, some of the attributes can be cut and pasted, and some cannot. If you edit the ones on the second sheet with your text editor then you will probably see a question mark in there that shouldn't be there.
The one that come to mind that I know cannot be cut and pasted are the page number, and the drawing scale.
So, what you need to do is edit the ones on your second sheet (with your text editor) and make them look like the ones on your first sheet.
