c.a 3mm for weld olet
Dear All,
My client is asking to reveice construction drawings with a c.a of 3mm, now if i'm correct this means i'have to enlarge my wt with +3mm, pls. advise.
RE: c.a 3mm for weld olet
What it means is that you need to subtract the corrosion allowance from the actual wall thickness when you are doing your MAWP calcs.
David
