Is there an API command for "Invert Selection" command?
It seems that "Sendkeys" command is no longer supported with 64 bit Windows system (Vista and Win7). I found many users are having the same issue with "Sendkeys" as I am.
Now back to my question, how do you use "Invert Selection" in macro? Is there an API command in Solidworks for "Invert Selection"? Recording a macro does not reveal "Invert Selection".
Before I upgraded to SW2010, I achieved this by using "Sendkeys" command with "I" (a shortcut for invert selection), which does no long work.
Best regards,
Alex
Best regards,
Alex
RE: Is there an API command for "Invert Selection" command?
-handleman, CSWP (The new, easy test)
Thanks for your advice!
To run swCommands_*, I need "SolidWorks 2010 Commands Type Library". But I am unable to find this reference with my SW2010 installed Win7 64.
Do you know if SW2010 has a commands type library?
Best regards,
Alex
Never mind. I found the reference
"SolidWorks 2010 Commands type library", and it is in "C:\Program Files\SolidWorks 2010\SolidWorks\swcommands.tlb"
Best regards,
Alex
