Restrictors in brake lines - what for?
I was recently working on a '96 Audi A6 Avant 2WD, ABS equipped. This has in-line restriction orifices located in each rear brake line where the caliper hose meets the hard lines. Being made from aluminium and located very much in the splash zone, these dissolve away quietly and eventually fail catastrophically - as in this case. They are also small and well hidden, so unless you know to look out for them, you'll not find the fault until the pedal hits the floor. Roads have been very heavily salted this winter which won't have helped matters. Perhaps surprisingly, replacements are also aluminium.
Question is, what function do they have? According to Audi they are only fitted to ABS equipped Avants (station wagon). The saloons don't have them. They can't have any true load proportioning action and the ABS effectively does this anyway. As far as I can work out, all they can do is delay the response of the rear brakes - maybe giving a damping effect under ABS deployment conditions?
Seems strange that the saloon, which is very close mechanically (I imagine spring and damper ratings are different, but other wise the same) is not thought to need them.
The car is currently running without them (on back order from Germany!) and both braking and ABS action seem normal. I'd prefer not to refit these parts (in aluminium at least), but would like to know what effect they are supposed to have before making a final decision.
Picture shows the opposite side, which hadn't yet failed - it's buried under the mud in that clip and looks just like the normal (plated steel) hose end.
[IMG]http ://i249.ph otobucket. com/albums /gg221/Vit esseEFI/Au direarbrak es001s.jpg[/IMG]
It was pulled off using two fingers only, becoming this....
[IMG]http ://i249.ph otobucket. com/albums /gg221/Vit esseEFI/Au direarbrak es006s.jpg[/IMG]
and the orifice looks like this - approx. 0.6mm
[IMG]http ://i249.ph otobucket. com/albums /gg221/Vit esseEFI/Au direarbrak es005s.jpg[/IMG]
Another worrying thing is that although the car has diagonal split line dual circuit, only one circuit was punctured, and the reservoir was not empty - this single fault caused total hydraulic failure. Surely this should not be the case?
If you happen to have one of these cars I'd suggest checking these parts out as a matter of urgency.
Nick
[IMG]http
[IMG]http
[IMG]http
Nick
RE: Restrictors in brake lines - what for?
So, I'm guessing the restrictors are present to limit the violence of brake apply/release cycles while the ABS is hammering away.
Mike Halloran
Pembroke Pines, FL, USA
Ironic, isn't it.
Maybe Audi expects you to replace the entire brake system before it corrodes away?
I'd get rid of the aluminum for sure.
Old-fashioned split systems allowed the pedal to go to the floor when a single circuit failed. You were expected to release and reapply the pedal, at which time the pedal would go halfway down, but the brakes would sorta work with the remaining circuit. When ABS arrived, drivers were re-trained to not release the pedal, ever. I wonder if the owners manual covers that exigency.
Mike Halloran
- Steve
It is probably a band aid cure for some dynamic manifestation discovered during testing.
The wagon will have somewhat more weight at the rear and the CG will be higher. This will have some influence on brake balance.
Also the difference between fully laden and lightly laden is typically greater in a wagon than a sedan, so the wagon should be more forgiving at the extremes even at a little cost to median conditions.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
They certainly do salt the roads in Europe! Lots this winter as it's been cold and snowy. Aluminium is a poor material choice for this application!
Spoke with the dealership again today. They confirmed these are used on the ABS equipped station wagons only. No-one there, even the "techs", has any idea what they are for! Disappointing, but not unexpected.
We all seem fairly well agreed that they are most likely dampers for ABS function on the rear. One thing bothers me though - I agree that the wagon could be more heavily loaded than the sedan, although oddly enough the vehicle handbook doesn't differentiate between the wagon and sedan for either vehicle weight or load capacity. However, I would have thought that early locking up of the rear and any ABS instability would be more likely under lightly laden conditions?
The vehicle handbooks says that ABS operation is made known to the driver by a "pulsating brake pedal and audible noise. This is an intentional warning to the driver that one or more of the wheels are tending to lock up. In this situation it is important to keep the brake pedal fully depressed so the ABS system can regulate the brake application. On no account 'pump' the brake pedal".
In fact, pumping the pedal did not restore any hydraulic function at all in this case. I don't understand why. I'll be bleeding the brakes once more in the morning, then taking the car to my local test station for a ride on their brake rollers to make sure both circuits are working properly.
A bit of surfing on the Audi forums suggests that this is quite common failure at the moment and there have been a number of close calls. Several are now running without the restrictors and are reporting no adverse effects detected.
Thanks for your time
Nick
Dan - Owner
http://www.Hi-TecDesigns.com
Parts-computer surfing at the dealer today shows ABS pump and ECU are the same between wagon and sedan as are calipers and discs. These restrictors seem to be the only system difference. Most odd.
There's now a fellow victim on one of the Audi forums who has a machine shop and is considering making a run of these parts in a stainless steel. I like the material change, some reservations about possible dimensional/QC issues.
Nick
Pat
for site rules
"To reduce the brake pressure at the rear axle and to adapt the brake pressure to the wheel load distribution a brake proportioning valve with a switch over pressure of 25 bar and a reduction factor of 0.46 has been fitted."
Sandy
