Pattern Format Problems With Attributes
Hey all,
I am using NX6, I have made a format template with automatic attributes, part names, sheet numbers, units, etc. I want to use the format as a pattern. All the part attributes show up just fine once the pattern is retrived into the drawing. But all the sheet attributes from this list dont show up.
<W@$SH_SHEET_NUMBER>
<W@$SH_NUMBER_OF_SHEETS>
<W@$SH_SHEET_SCALE_NUMERATOR>
<W@$SH_SHEET_SCALE_DENOMINATOR>
<W@$SH_SHEET_SIZE>
<W@$SH_SHEET_UNITS>
<W@$SH_SHEET_PROJECTION_ANGLE>
<W@$SH_MASTER_PART_NAME>
<W@$SH_PART_NAME>
The only attribute that shows up from the 'sheet attributes' is 'the number of sheets' (<W@$SH_NUMBER_OF_SHEETS>)
Any ideas what im doing wrong? Its something to do with the pattern - when I import the format template as a part all the attributes work just fine.
HELP PLEASE
RE: Pattern Format Problems With Attributes
Russkiman,
Are you using Master Model for your drawings?
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
NO sir... I am not
Hmmm,
just tested them out and they work fine.
Do you add them in your drawing sheet, or are you setting up a Template and add these nominators in your "modeling" view?
Best regards,
Pascal,
I am adding them to the drawing sheet. it seems that when the boarder is saved as a pattern for some reason those attributes do not work??
Talked to siemens apparently it's a known issue. they are working on a fix
