Selection Mask Journalling Problem
I'm using a selection mask to allow users to select objects from the screen.  I'd like to allow the selection of a type of object eg face but not have it selected in the object type in the selection dialog until the user goes in and changes which objects to select.  I've seen this done in bulit in selection dialogs in UG before but can't find how to do it in a journal below is my code:
Dim my_ui As UI = ui.GetUI
        Dim message As String = " Select Objects To Link"
        Dim title As String = "Selection"
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim keepHighlighted As Boolean = False
        Dim includeFeatures As Boolean = False
        Dim response As Selection.Response
        Dim selectionAction As Selection.SelectionAction = _
            Selection.SelectionAction.ClearAndEnableSpecific
        Dim selectionMask_array(5) As Selection.MaskTriple
        nxs.listingwindow.open()
        With selectionMask_array(0)
            .Type = UFConstants.UF_solid_type
            .Subtype = 0
            .SolidBodySubtype = 0
        End With
         With selectionMask_array(1)
            .Type = UFConstants.UF_line_type
            .Subtype = 0
        End With
        With selectionMask_array(2)
            .Type = UFConstants.UF_spline_type
            .Subtype = 0
        End With
         With selectionMask_array(3)
            .Type = UFConstants.UF_circle_type
            .Subtype = 0
        End With
            With selectionMask_array(4)
            .Type = UFConstants.UF_face_type
            .Subtype = 0
        End With
        With selectionMask_array(5)
            .Subtype = 0
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_EDGE
        End With
        Dim selectedobject() As NXObject
        response = my_ui.SelectionManager.SelectObjects(message, title, scope, _
                                                        selectionAction, includeFeatures, _
                                                        keepHighlighted, selectionMask_array, _
                                                        selectedObject)
        If response = Selection.Response.Cancel Or response = Selection.Response.Back Then
            ' / Exit execution /
            Exit Sub
        End If
Mark Benson
Aerodynamic Model Designer
To a Designer, the glass was right on CAD.
