Diaphram Design w/o Plywood
I'm looking to design a very small park restroom facility. The building will have no electricity so I would like to use "clear" fiberglass panels as the roof sheathing. This way I can get as much light in as possible.
My question is how do you design a diaphram like this?? All the wood (timber) books that I have show using plywood to create the diaphram...since this is what a diaphram is
Will the fiberglass panel manufacturer have an "equivilent" plywood rating??
OR can this be done by using a certain cross-bracing pattern on the trusses??
I'm essentially trying to determine how to get the wind to the shear walls. Any ways to do it w/o using the roof?
I don't normally (read: ever) design wood buildings so I apologize if this is a "simple" question.
All suggestions appreicated.
RE: Diaphram Design w/o Plywood
Or provide horizontal x-bracing to create horizontal truss to transfer load to shear walls.
The biggest problem in this type of building is to make sure it is adequately anchored to resist overturning and sliding with sufficient safety factor.
