Calculating welding volume
Does anybody knows any formulas to calculate the amount of welding material used when welding pipe. The used weld is a V-shape and a X-shape weld.
I want to calculate the amount of material when welding pipe. I know the pipe diameter and the wall thicknes.
http://www.costengineering.eu/
http://nl.linkedin.com/in/leendertdegeus
RE: Calculating welding volume
Calculate volume of the weld joint using the pipe circumference. You obtain cubic inches, and use the density of steel to calculate weight. You should be able to do the rest.
I do know that. But as you can see I'm an elictrical guy. so I wondered if somebody had a kind af excel sheet where I just could fill in the pipesize and wallthicknes and weldshape (V-shape, X-shape or something else) and it would give me the material volume. But if not I have to dive into the "Poly technisch zakboekje" (Poly technical handbook) and try to create this myself. But then I'm not sure I did the right thing.
Leendert;
All it takes is a little trigonometry and simple algebra.  It would take 20 minutes to set this up. Why do you need to know the volume of weld metal?
If you're calculating material usage, be cognizant of the fact that the various processes have radically different efficiency factors, e.g. - 1 pound of SMAW electrode will not yield one pound of weld metal.
I'd suggest you get Lincoln's Procedure Handbook of Arc Welding.  There's an entire section devoted to calculating welding costs.
unclesyd -
I don't know who O. Bridgette is, but the book you refer to is written by Omer Blodgett.
Adm Vakiener, P.E.
Adam Vakiener, P.E.
It is Omar Blodgett,s "Design of Weldments", sorry for the typo.
The book is $15.00 and well worth it.
PS: The book was $3.00 when I bought my first copy.
At that price, was it still in hieroglyphics with hand-carved block engraving, or had Gutenburg finished the second edition yet?   8<)
@metengr
I need to volume because I know the average volume per hour per welder. So when I know my total volume I can calculate the number of manhours needed to complete the weld.
@all people who reacted
Thank you very much you've been very helpfull.
A little upfront warning there is no standard speed/volume of weld metal deposited by any one welder.  There are too many variables.  You can only accomplish this if the welding is automatic. I have a friend who owns a ship yard and he has tried several approaches to quantify weld product per welder.  After he announced he had determined each welds speed the welders went right out and turn his numbers around.  The faster welders got slower and slower got faster.
He tried another scheme to measure productivity by having each welder puts his stubs in bucket to weigh against the amount issued.  His intent was to prorate the pay depending on the amount of weld deposited.  He used this system for about 6 months until his accountant show him that welding costs were appreciably high.  The welders were burning the electrodes right up to the holder and burning the holders up.
