Section Modulus - Masonry Wall
Is it accurate to calculate the section modulus of a masonry wall for in-plane bending (shear walls) using an equivalent solid thickness and treating it as a rectangular section?
I have looked in NCMA TEK, but do not see any calculations for in-plane section properties.
RE: Section Modulus - Masonry Wall
DaveAtkins
In case of a grouted wall (with say 24" or 16" o.c), that can add up to a significant bump in the section modulus. Do you still only consider face shells?
The properties for the section moduli of grouted walls, partially or otherwise, are in the CERM
The properties in the CERM or any TEK publication is for out-of-plane bending (with walls spanning vertically or horizontally). It is not for in-plane section properties.
I hastily read the OP.
Do you mind my asking why it is necessary to calculate this for your application. I don't get into masonry design much.
DaveAtkins
