ASTM A400 Class Q2
ASTM A400 Class Q2
Can someone tell me what material/materials would meets ASTM A400 Class Q2?
RE: ASTM A400 Class Q2
4.1.2 Classes Q-1 through Q-7 comprise bars for parts
operating under moderate service conditions requiring moderate
to high yield strength (75 000 to 185 000 psi (517 to 1276
MPa)), corresponding tensile-strength levels, and good ductility.
The applicable section sizes, identified as Classes Q-1
through Q-7, are shown in Table 7. The steel compositions
suitable for Classes Q-1 through Q-7 and various desired
mechanical properties are listed in Tables 3 and 4.
Don't guess, you need the ASTM sepcification because the list of steels for Class Q-2 are shown. The cost of the standard is below,
http://www.astm.org/Standards/A400.htm
If your company cannot afford $39 USD, time to find another job.
Come on, only $39 USD, are you serious? How can you prepare a quality bid when ASTM A400 is called out for steel composition and mechanical properties??
