Impact values on Hastelloy C276 cast steel CW12MW
Dear All,
we have produced one sand cast body acc. ASTM A494 CW12MW (corrispondent of Hastelloy C276); it's a pressure containing part, therefore customer requested us to carry out an impact test at T=room (not requested by ASTM A494), guaranteeing 27J minimum.
Now, we have carried out the tests, finding 8% elongation (4% minimum required by ASTM) and impact test 14-12-11J (much lower than additional request of 27J made by customer).
Practically speking, my impression is that a material whose minimum elongation is 4% will hardly be able to achieve an impact value higher than 27J, but I would like your opinion on the matter.
Thank you in advance for your help
BR
Marco
BR
Marco
RE: Impact values on Hastelloy C276 cast steel CW12MW
I would suspect you have a quality problem with these sand castings. I do agree that your properties will be much lower for the casting form in comparison to wrought product form, but I would believe you should easily reach 27 J at RT.
Look at casting quality and check thermal treatment that was performed for the sand casting.
Have these been solution annealed?
Plymouth Tube
_____________________________________
"The richer we have become materially, the poorer we have become morally and spiritually." Martin Luther King Jr
We will keep investigating.
Marco
