Part families and Reuse library select options
I've created the template file of my model. There are 30 different versions of my template with unique part numbers that I deal with using part families and Reuse library. When I create the KRX file for use in Reuse library, I choose that users can browse all 30 articles by part number. But let say I only have 15 articles in stock. Is it then possible to display all 30 articles but only let the user be able to choose between the 15 articles in stock? I want the 15 articles that are NOT in stock to be "greyed out".
I use NX 7.5.
Cheers
RE: Part families and Reuse library select options
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
But then I have to figure of something else. Thank you.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thanks.
Then you right click your template and choose "Create KRX file". Now you can choose the parameters from your part family that you want to use.
Best of luck
