Problem With Nfpa 14!!! What is THe criteria for selecting the class??
Hi, i have a problem with the criteria for the selection of the system class?? In the norm it only says the different tipes of systems (Class 1, Class 2 or Class 3) but it doesnt say anything about wich one to use depending the hazard?????
I hope some one could help me with this. Thanks
RE: Problem With Nfpa 14!!! What is THe criteria for selecting the class??
The building code determines what type of standpipes. What is the applicable building code?
If you can answer that, perhaps we could be more help.
Find out what the governing code is in the area you are working (for example the IBC). Also, certain municipalities (AHJ) can have their own codes that will override it for a more specific application.
Then depends on the occupancy group
Size of building sometimes
And if the building has a fire sprinkler system
Also sometimes the fire code will dictate standpipe uncertain hazards
The big questions are:
1) Wet or dry
2) Manual or automatic
We can't work that out for you. Good luck.
