Cracked MOI for PT Slabs
ACI 318-05 [10.11.1] allows the use of the reduction factor 0.25Ig for estimating the cracked MOI for concrete flat plates. However, that is not for prestressed flat plates. Assuming a minimum precompression of 125 psi, would not the cracked MOI be something higher than 0.25Ig? If so, what would be a reasonable factor to use? Remember this section is referring to estimating the cracked MOI for the ultimate load case and not the Ig used in computing deflections for the service load case. Thank you in advance for your help.
RE: Cracked MOI for PT Slabs
Using an estimate nlike this for the RC is very approximate as it will vary significantly with steel ratio!
