dim style mapping
dim style mapping
RE: dim style mapping
When you create a new file you make a 'copy' of the template to start with.  So updating the template will not be reflected in already created files.
Also, please try not to start a new thread for what is effectively an extension of your other thread, you can reply in your own thread if you need to add clarification etc.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
